Side 12> |
trackpad ![]() Junior bruger ![]() Oprettet: 07-August-2008 Status: Offline Point: 21 |
![]() Sendt: 17-August-2008 kl. 17:23 |
My written Danish is pretty bad, so I'll write in English and hope you understand. Men De må gerne svar tilbage på Dansk, det der
helt fint... I read this little bit about the NAD 755 and it had me concerned. *** "Even more surprising at this level is the lack of audio support via HDMI. Despite being classified by NAD as v1.3, the HDMI inputs only pass through video; you'll need to connect an optical lead or make a multichannel analogue connection to your source to hear anything." **** Full review Does this mean that I can't connect an Xbox or a DVD player over HDMI and get the audio without also connecting a separate cable to the same device for picking up the audio? If "yes"...why? Isn't that missing the whole point of HDMI? And is this normal for other receivers? I was also considering a Sony STR-DG-820 but would probably avoid it if this were also the case. How is your own receiver handling this? I would also welcome recommendations if you know of a model that simplifies things by sending audio and video over the same cable. I have a budget of 6.000 Kr. |
Hans j ![]() Guld medlem ![]() ![]() Oprettet: 02-Marts-2007 Status: Offline Point: 4207 |
Der skal bruges separat lydkabel.
Sony STR-DG 820 er lige blevet rakket ned i T3, men det er måske heller ikke det mest seriøse blad, men de havde trods alt den rigtige vinder (Onkyo) ![]() Der findes forskellige modeller, som ikke har lyd med via hdmi, f.eks. den mindste fra Onkyo (TX-SR 506) har heller ikke. Hvorfor de laver disse halve løsninger er nok pga. prisbillig alternativ. De kan jo i princippet tage en gammel model og forholdsvis nemt smække en HDMI videoswitch i, voila en SR med hdmi til billig penge. |
Kan da ikke være så svært med et budget på 6k. Onkyo 606, 705, 805 kan fåes til de penge, og her er ét HDMI kabel tilstrækkeligt.
Yes... I might have to get used to the look of the Onkyo series. Aesthetics
are a bit of a concern for me as well unfortunately. I can't believe the NAD which is up around 6.000 Danish couldn't manage this. Pretty disappointing. I will check out the Onkyo's again. Any other suggestions? |
Just get it in black! It's a beauty
I guess beauty is in the eye of the beholder :-), Although I am really in
favor of silver as a general rule, the black is - you're right - in this case better. It hides the black stripe which otherwise makes the silver model look a bit dated. In other news, the STR-DG-820 does pass audio. But one thing I did notice is that it is extremely slow to switch between sources. Maybe it was the TV, but it seemed to take 5 or 10 seconds to detect the audio and video and begin passing the signal from the Apple TV to which it was connected. Is THIS normal? Sorry, but I am a HiFI noob. I would have expected that when I changed the source on the receiver from say, DVD to VIDEO 1, that it would be almost instant. We are living in 2008, right? |
Yah ok. Point taken! Untill a year ago all my equipment was in silver. But now I really love the new look i black, stored in a whitewash furniture. It isn't an issue for me to wait 10 sek for the Onkyo to shift between sources. Well I'we got used to 60 sek for the BD to load a film. I think thats very normal because the reciever needs to detect the incoming signal and do several switching between the inside components. Switching between analog signals is far easyer. Yes the year is 2008! But AV equipment is getting far more complicated than we ever thought of. |
furious jt ![]() Guld medlem ![]() Oprettet: 23-Marts-2007 Sted: Denmark Status: Offline Point: 3730 |
Kampus, er det din trojan virus der får dig til at skrive engelsk trods trådstarter skriver han forstår at læse dansk Anywhooo. Hvad med en denon 2308? Redigeret af furious jt - 18-August-2008 kl. 15:03 |
7.2.4 atmosbio
Sony vpl-HW55 Diy 116" fastramme lærrede. Marantz av7702mkII - Marantz mm8077 og NAD M25 Oppo bdp-83 Regionsfri 5 stk. MK Sound 150mk2. 2 x Mksound X10 subs |
Hi hi, ja det kunne man da godt tro. Sidder og kæmper med Mansion Casino og Køb PS3 og en hel masse LORT!!! Nu bliver han ved med at snakke om Sony 820, men den kender jeg ikke til desværre. Måske kan du fortælle om Denon, du er jo ekspert!!! |
bruger udmeldt 5 ![]() -- ![]() ![]() Oprettet: 15-April-2006 Sted: lolland Status: Offline Point: 3584 |
Præcis hvad menes her? At man IKKE skal tænde receiver, når man vil se signal fra sin PS3? f.eks? eller? for med 4 indgange og kun 1 udgang ved jeg ikke hvordan video/audio passthrough skal fungere, med 3 signaler? (i mit tilfælde STR-DG720) |
Som jeg forstår det kan NAD755 _ikke_ modtage lyd via HDMI til trods for vers. 1.3. Og derfor er nødt til at have optisk eller 5.1 anlog forbindelse også. Så det han efterspørger er vel om Sony 820 kan modtage lyd via HDMI? |
@ Kampus "It isn't an issue for me to wait 10 sek for the Onkyo to shift between sources."
Do you mean it doesn't take 10 seconds for the Onkyo, or that you don't mind that it does? :-) I think it's absurd, frankly. These are small computers, they should be able to handle it. It's probably the HDMI spec which is to blame, maybe doing all kinds of hand-shakes and making sure the source and destination are authorized. (SUK) The thing that really troubled me about the 820 though was that it seemed like if you were watching a source, say your Apple TV, and then you turned off the unit - when you turned the unit on again it didn't seem to feed out a signal to the TV again until you select another source and then go back. To sort of wake it up. What a drag! I guess my expectations are pretty high. And I agree things are getting more complicated but....but 10+ seconds??? The only good news is that the 820 did take sound and video together from the single HDMI connection. That was nice. But the overall build quality of this receiver is a definite minus. It is also almost half the price of the NAD or the Onkyo 606,...so I guess they saved money making it in plastic. And I could live with that as well if it were maybe a little better to switch sources. @furious jt - I am going to check it out. Don't know much about Denon frankly but the more I learn the more impressed I am. @pendec, ...the original post was about the lack of ability in some receivers to pass audio with the video over HDMI. I would like to have 3 HDMI sources (Apple TV, Xbox, and an HV20) connected and be able to switch between them and to hear them without also attaching an optical line or analog cables. Since then things have devolved into my complaining about waiting for source switching (10 seconds!?), and also taking recommendations on other alternatives. |
Side 12> |
