  Nye indlæg Nye indlæg  Seneste forum emner Seneste   Seneste forum emner (vindue) Vindue   De emner du deltager i Mine emner RSS Feed - bedste blu-ray player
Emne lukketbedste blu-ray player
the_rieper Se dropdown menu
Oprettet: 01-September-2006
Point: 545
Direkte link til dette indlæg Emne: bedste blu-ray player
    Sendt: 19-Maj-2008 kl. 21:26
ifølge kloge folk på avsforum byder de nye pioneer afspillere (BDP-51FD
og BDP-05FD) på den bedste billedkvalitet på markedet! her er et lille
uddrag og link.
The HDMI High Speed Transmission feature scales a BD discs 8-bit color
signal to 12-bits per channel resulting in a 36-bit color signal. We
actually interpolate what colors were lost in the creation of the BD disc by
comparing 3 video frames (compare frame 1 to frame 2 and frame 3 to
frame 2). We have seen some content from the Pixar folks that utilize 14-
bit color.
The circuit is quite effective. We gave a demonstration showing a 100
grey scale chart from both a Denon 3800 and our new BDP-05FD. We
utilized two PRO-FHD1 plasma displays. On the Denon player you can
clearly see the lines between each gradiation of grey. On the Pioneer
player with this circuit activated the same image showed a perfectly
smooth grey scale (No lines).
The end result is that the player now can choose from a pallet of 69
billion colors instead of the 16.7 million that the 8-bit players use.
This does take up more bandwidth on the HDMI cable. In longer runs you
need to make sure that the cable can handle it. (Around 220Mhz).
When I get back to the office next week I will see about doing some
screen grabs from both players to post...
eep color was developed for future BD and HD DVD, but to date has not
been authored on and discs. Deep Color adds more colors to the pallet.
To date no sources are available with Deep Color.
However, Pioneer's new BD players, 05FD and 51FD up-convert the BD 8
bit per color disc to output 12 bit per color channel. Effectively, this
increases the useful colors from 16,7000 to 69 billion colors and honestly
if I did not see it with my own eyes I would not believe it either. The pq is
truly improved, better color accuracy, better color saturation and
definition, the image looks more 3-D.
Pioneer achieves this in its new 36 bit DAC that looks at each color (RGB)
in the frames in advance and actually interpolate what colors were lost in
the creation of the BD disc by comparing 3 video frames (compare frame
1 to frame 2 and frame 3 to frame 2).
Honestly when you connect these new 4 Gen Pioneer BD players with the
9 Gen Kuros you get a image that is appreciably improved and can easily
be seen by anyone. These devices are very well matched to take
advantage of each other's powerful HD image reproduction capabilities.
Hey anyone see my road show pictures yet?
http://www.avsforum.com/avs-vb/showthread.php?
t=1027097&page=62
Redigeret af the_rieper - 19-Maj-2008 kl. 21:27
MortenMJ Se dropdown menu
Oprettet: 23-Oktober-2006
Point: 822
Direkte link til dette indlæg Sendt: 21-Maj-2008 kl. 08:56
Er det både på BD og DVD siden at den bliver god mon?
Jeg skal gerne have en BD-afspiller på et tidspunkt, men den skal gerne kunne klare DVD-film med et rigtigt fornuftigt billede også, da jeg helst ikke vil smide min DVD-samling væk.
Dondee Se dropdown menu
Oprettet: 28-December-2007
Point: 136
Direkte link til dette indlæg Sendt: 21-Maj-2008 kl. 09:08
Jeg kan kun anbefale Samsung BDP-1400. Den viser dvd så engelne synger. Og så er den i orden prismæssigt.
Otto J Se dropdown menu
Branchemedlem
Oprettet: 04-Marts-2007
Point: 11218
Direkte link til dette indlæg Sendt: 21-Maj-2008 kl. 09:16
Interessant. Et par kommentarer: Jeg kan ikke gennemskue hvad pointen skulle være i at kigge på tre frames for at interpolere. Hvis dét testbillede de taler om er en stillestående gråskala, hjælper det ikke noget at kigge på en frame før og efter, så er interpoleringen en decideret interpolering mellem pixels der ligger ved siden af hinanden. Hvis denne interpolering er "låst" til kun at ændre en pixels værdi i 12-bits opløsning "inden for" det område den oprindelige 8-bits opløsning tillader, så kan det sagtens virke, og levere mere flydende gradienter i praksis. I dén forbindelse skal det nævnes at farve-information lagres på en blu-ray skive i kvart opløsning, så der foregår _altid_ interpolation af farve-informationen - interpolation er i sig selv ikke nødvendigvis af det onde.
Hvis man overdriver effekten, og bruger den til at glatte alle gradienter ud, også selv om overgangen mellem dem er grovere end dén banding 8-bit opløsningen medfører, så vil det give risiko for issues meget lig noise reduction.
Mht. båndbredden, så understøttes 12 bit per farve også uden Deep Color, hvis signalet overføres som 4:2:2. Hvis det overføres i RGB, så er det en væsentlig forøgelse af båndbredden, som ganske rigtigt kan give issues hvis man har lange kabler, og disse kabler ikke er i god nok kvalitet. Dette er et rigtigt godt argument for at betale lidt ekstra for gode kabler, især hvis kablet installeres mere eller mindre permanent (trukket i væggen, over loftet etc) - én ting er at det virker med dit nuværende udstyr, men det skal også helst virke hvis du skifter afspilleren ud med en afspiller der laver tricks ala dette.
Branchemedlem
Point: 11218
Direkte link til dette indlæg Sendt: 21-Maj-2008 kl. 09:17
Det kommer vist an på hvilken engel det er vi taler om...
lunddal Se dropdown menu
Oprettet: 09-Februar-2006
Status: Online
Point: 8703
Direkte link til dette indlæg Sendt: 21-Maj-2008 kl. 09:30
Sikkert for at tjekke om det ikke bare er en evt. fejl/uhensigtsmæssighed i den enkelte frame og for at se hvor billedet er "på vej hen" hvis du forstår hvad jeg mener.
