Forfatter |
Emne Søg Emne-funktioner
Apros
Oprettet: 10-Maj-2006
Point: 185
Emne: HD-E1 opdatering af firmware Sendt: 09-Februar-2007 kl. 08:27 |
Så kom der endelig en officiel mail fra Toshiba UK omkring ny firmware.
Er der nogen af jer, der allerede har opgraderet til 1.205, som har haft problemer med at afspille HD-DVD fra USA (region 1)?
/Anders
Nedenfor er mailen gengivet:
"Thank you for registering your interest in receiving the latest
news and firmware updates from Toshiba. Please see below firmware update for the
HD-E1 HD DVD player.
Firmware Update Version: 1.205 Applicable Models: HD-E1
Overview: This firmware update addresses
certain disc playback and HDMI/DVI related problems identified by
Toshiba.
How to obtain and install the update: If you
have a broadband internet connection you can obtain the update on-line using the
Ethernet port in the back of your HD DVD Player. There are instructions for
configuring the Ethernet port on page 44-45 of your user manual. Page 58 of the
user manual describes how to download the firmware update. Here is an overview
of how to proceed:
• To configure the Ethernet port you may need to turn
on the DHCP setting. Page 45 of the user manual explains how to do
this.
• After you have configured the Ethernet port, follow the
directions on page 58 to check for a firmware update.
• If an update is
available for your player, it will take about 30 minutes to download and
install.
• PLEASE DO NOT TURN OFF THE POWER TO YOUR PLAYER during the
update process – doing so could cause the player to malfunction.
• If no
update is available, the player will quickly exit the update process.
Please refer to your owners manual for full details.
If you do not have
an Ethernet-based broadband connection or prefer not to use one, you may contact
Toshiba Customer Support and request that a firmware update disc be sent by
mail.
• You can update the firmware using this update disc by following
the instructions provided with the disc.
POWER TO YOUR PLAYER during the update process - doing so could cause the player
to malfunction.
Please note: If you sent Toshiba the Firmware Update
Request card included with your player, you will receive an update disc by mail
from Toshiba as soon as it becomes available.
Frequently Asked
Questions: Q1. The HDMI output doesn’t work
or works intermittently with the HDMI or DVI input on my HDTV or monitor. Does
the new firmware address this problem?
A1. Yes. The
firmware update will fix any problems with HDMI and DVI connectivity. Should you
continue to experience problems, please contact Toshiba Customer
Service.
Q2. During HD DVD playback I sometimes
experience pixelization or ‘block noise’. Sometimes playback stops. Sometimes,
playback is not smooth. Does the new firmware address these issues?
A2. Yes. The firmware update addresses a number of
playability issues. You should also check that the disc is clean. If the disc
does not operate at all, check that you have inserted the disc the right way up.
If you continue to experience problems, please contact Toshiba Customer
Service."
Hother
hummelmose
Oprettet: 12-Juli-2006
Point: 23900
Sendt: 09-Februar-2007 kl. 09:07 |
Hej apros - nej jeg opdaterede firmware i onsdags, og jeg har ikke haft problemer med afspilning af region 1 HD DVD.
Apros
Point: 185
Sendt: 09-Februar-2007 kl. 12:40 |
Hother skrev:
Hej apros - nej jeg opdaterede firmware i onsdags, og jeg har ikke haft problemer med afspilning af region 1 HD DVD. |
Det lyder godt. Har du oplevet nogle af de andre problemer, som firmwaren skulle løse? Det har jeg nemlig ikke. /Anders
Hother
hummelmose
Point: 23900
Sendt: 09-Februar-2007 kl. 12:46 |
Hej igen apros - næh jeg kan faktisk slet ikke mærke nogle ændringer overhovedet. Jeg har nu heller ikke observeret nogle af de problemer som "Release Note" nævner.
Jesper Nielsen
Oprettet: 15-Februar-2004
Point: 134
Sendt: 11-Februar-2007 kl. 15:14 |
HD DVD er ikke regions kodet som dvd og de fleste blu ray film er..
Jesper Nielsen
Hother
hummelmose
Point: 23900
Sendt: 11-Februar-2007 kl. 15:32 |
Hej Jesper - jamen jeg er da fuldstændig klar over er HD DVD er regionsfri - men spørgsmålet gik på afspilning af DVD region 1, så det var det jeg svarede på. Problemet har nemlig været, at Tosh´en havde problemer, med ikke nærmere specificerede DVD´er. Derfor spørgsmålet
